Well I got this thing a few weeks ago for 2k. Rode everyday and hard by me, last guy was older and easy on it. Anyway. Need some help. Posting pics and info below<br />
<br />
enepy9ug.jpg<br />
<br />
Alright. Why are my tires rubbing so different?!?!<br />
<br />
y4a6a6y4.jpg<br />
<br />
What is oozing from front axle? Should I worry?<br />
<br />
y3u6ajyh.jpg<br />
That's from rear axle, worried about that oozing black stuff. It was all by my finger. What is it?! <br />
<br />
Also brakes have nothing. Where do I start with them?! And where can I get a cheap solenoid and tires?! Thanks!<br />
Sent from my iPad using Tapatalk HD
tires are probably wearing like that because of camber and toe in/toe out ...
the boot may have lost the seal from the clamp or dirt worked its way in and you are losing cv grease ...
the last pic looks like a worn seal, and you are losing gear oil ...
if it isnt a big deal for you and like its not something you want to do right away, yah, just top it up as you go. it might look like alot is leaking, but is probably very little ...
and tires, if you get new fronts, keep the air even in both, like 4-5 pounds each. that could have been something that contributed to the wear too ...
Went to the store.. Got 80w gear oil one of the better ones, some cv grease (time to replace boots), and 5 1/2 quarts of 10w-30.. Any how tos for all this?
fill the gear oil from the top bolt, look for a fill level mark inside. pack as much as you can for the cv joints, motor oil or atv oil? you need atv oil for the hondas transmission (hp4 i think). i always used honda oil when i had my hondas, tried tested and true ... only need a couple quarts for a change i think ...
2.3 quarts lol. I let a friend change it and he put in castrol motor oil 10w-30 synthetic. Is that ok? How exactly do I pack the CVs? Alright and that bolt is beyond stuck?!
As long as the oil says wet clutch safe then the oil is ok. I would pack the cvs by hand as much as possible then dump some grease inside the boot. Was told if dirt does get in there it would stick to the boot instead of going to the cv due to centrifical force....wishful thinking maybe lol
Sent from my SGH-T989 using Xparent BlueTapatalk 2
If your in the U.S. then your oil is in quarts, but that bike is foreign so its a metric version. It should tell you right near the dip stick tube if its a 1000ml or 2000ml. one litre is 1000ml. Just get a conversion chart from the net and itll tell you the difference between a litre and a quart.
Also, if oil is getting out of the rear end then if you ride it in water, water is getting in, so keep it full until you can arrange or afford to have the seals replaced otherwise youll have a rear end gear problem.
Good luck
  • 3 months later...
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
