Similar Tagged Content
By SG082279
my quad stalls and cuts out ..
and i just put a band new carbarater what else could it be
By Bajarider
Just happened to find a Can-Am BRP dealer in town, so you know I had to check it out! They only had Outlanders, and some Jet skis, and you better believe they weren't cheap. I don't think that just over 28,000 USD for an Outlander is a good deal! After chatting with the sales people, they let me know that they had only sold two of the quads so far. They had no idea where someone could ride them and since there are not too many pickups or trailers, there is no way to get them from one place to another without hiring a rollback truck. Seems like a little too much trouble for me.
Similar Topics
By NathanFisk
I have an 2003 Kodiak 400 Automatic and for some reason the starter not engaging I’ve replaced it still nothing it spins freely but not engaging. It was running fine the day before I am no expert so can someone please help me
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By Randel1
I'm having a problem getting a CDI unit that works. The parts list calls for a 4XE-85540-00-00 CDI unit. The one currently on the ATV works but there seems to be a problem with the spark advance curve. It will idle fine an rev. to about 1.5K then starts bogging down sputtering, popping and basically running poorly. If you can get it above 2200 RPM it runs better. I have ordered and returned about 5 replacement modules that will not work at all. The unit currently on the bike has no part numbers or identification other than a Mitisibuchi logo. I am wondering if anyone else has experienced similar problems with replacement CDI's and if so what is the fix? So far I have not found a replacement CDI that will supply an pulse to the Ignition coil.
By NoahJakavi
Hello i have a linhai 300 of the 2004+- era. I had a cluch problem so we changed it. After changing it has a hard time to start going. When you pop it into gear and press the gas it barely drives but when it starts going about 20km/h it start driving well the acceleration is normal and everything do you have any idea of what could be the problem
