By oztrax
MAX 4 6X6 2008
By HoldenBoy
Hi all,
By WyattLemke25
Having problems with the battery draining while riding. It has a new battery, it does have eps, a lightbar and a winch. Can ride it for an hour or more just fine, but eventually the battery runs down to the point it can't keep up with fuel injection and it'll sputter, limp, and die. It also throws codes for the throttle position sensor. I'm not sure if that is related or not. Any ideas?
By cervenakrava
Hi,
New to ATV repair but willing to learn and get my hands dirty.
We start the atv and even with a good battery, it will drain it very quickly and eventually the atv shuts down. Checking the battery afterwards shows significant drain on it.
Would this be a shot alternator? Some electronics module?
Thank you kindly. Just need to be pointed in the right direction and then with a repair manual will get to it.
Cheers
