Found Article
By Ajmboy
Starting a new topic for the 2024 Presidential Elections. Please be respectable with open discussion 🙂.
2024 Presidential Polls:
RealClearPoltics
FiveThirtyEight
270toWin Interactive Map
Previous topics (now closed):
By BuckBilly
By kawasig
Hello there
By Suzukiquad
I have a 97 Yamaha Timberwolf and it is beyond loud, is there any good options to silence them or at least make them bare able to drive. I know it has a crack in the exhaust pipe, but even with that fixed its still loud.
By DarkRider
Hey everybody,
Just curious on some opinions on my recent buy. I'm a big fan of the drivetrain and transmission in the Suzuki King Quad 300 and QuadRunner 250 4wd models. I've been wanting one of either model for quite some time, and recently picked up a really nice shape one for 1500. I just wanted to get some opinions on whether you'd be more hesitant to get something this old, if there are newer options that are comparable.
Also just keep in mind this is coming from someone not super mechanical.
Key factors:
Engine doesn't appear to have any leaks Had to replace the battery for $100, no biggie Front left CV boot is torn (not yet sure if the axle has damage) Starts right up with the tap of the button every time (so far) Idle was a bit low and was shutting off when warm. Adjusted the idle. Now it will only shut off occasionally on a hill if I'm not rolling or giving it gas. Has a Harbor Freight Badland winch with a wireless remote (brand new, tested and working) Has brand new shocks and brakes Shifting gears and changing between 2wd/4wd/diff lock/high/low/super low all seem fine. Rides pretty good, tight steering, takes the bumps pretty good as I have pretty rough trails. Brand new tires Over 2000 miles, that's quite a bit, but it seems well cared for. Plastics are almost all there. It's really only missing a small bit of the black mud flap in the rear. Has minimal stitching in the front, and it's got the usual scuffs. All of the lights work just fine (Neutral, Reverse, high and low beams) Tested the charging system and that works
And I think that's just about all I can think of at the moment. It mostly seems to be complete and all there. I was a little hesitant about getting something that old, as parts are always a concern. Looks like most parts are available, but axles seem to be hard to get if you want something brand new. I really wanted a 2000's model but I couldn't pass up the price.
Similar Tagged Forum Content
- 0 replies
- 1,725 views
Please Read My Article about the Championship Mud Racing Season Opener
By CJRenaJohnson,
- article
- championship
- (and 5 more)
- 0 replies
- 1,758 views
- 3 replies
- 4,323 views
- 2 replies
- 3,192 views
