I am in the process of putting a rear swing arm on an atv, and by the way it looks i have to pull the rear differential off the swing arm to get the spline shaft back into place on the differential that comes off the back of the transfer case.. Anyways i got the brake assembly off the hubs off and the two ring nuts and cant get the axle shaft to slide out of the rear differential, i am using a block of wood and a good size hammer and hitting the axle on the left hand side if you were standing behind the machine... can a guy try a press??? any help would be greatly appreciated...
i think maybe if its got a spline and no clip, you might have to beat it off ... would heat help do you think?
i would have to split the differentail to do any heating i think on the ring gear or bearings
Got the axle out!! I put the swing arm back on the atv and the hub and nut and used a impact socket and sledge hammer and beat it out.. also took the differential off and noticed it needs a pinion bearing and seal, and it also looks like a person needs a special socket to get the pinion bearing out...
    • By middlebrookgt
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
    • By TravisCr
      I live in North Eastern Wa, in Collville, and I'm trying to figure out if there are any good regional used parts dealers around here- Our town had a decent Polaris dealer- but dealer prices are what to be expected these days.
      I've got some random little pieces I'm looking for and tired of scrolling ebay (2003 Polaris Sportsman 700)
      These are odds and ends stuff and I'll probably end up on ebay- but figured I'd ask.
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
