Hello everyone I am new here. I bought a 2001 Suzuki KingQuad LTF-300F reciently. it has been running great, however I herd clunk, it turned off, I tried to crank it over but no go. any suggestions would be helpful!
Edited by Chris_Highlander
Slow down guys. My ltf500F had something that sounds similar happen & it was a malfunction in the pull starter. I pulled it apart & the end of the spring had broken off & jammed everything up. I flew aprat when I took it off so I put it back together how I thought it might go (after grinding a new slot in the end of the spring) & it works fine. It did appear that the motor was locked up but it freed right up once I removed the pull start. Id check there first, then dig deeper. Just my opinion.
    • By kevinohio
    • By buriedpast
