Sorry I didn't post this vid sooner, but it's taking forever for the forum web site to load (for me anyway) & I get frustrated pretty quick.
I got a new Rigid SR2 6 inch LED Light bar in a DRIVING pattern I won in a photo contest and I FINALLY got it mounted. So, I wanted to go for a night ride to see if it made much difference when added to the Rigid SR-M's I have on the handlebars, which have a SPOT pattern & the Rigid Dually's in a FLOOD pattern.
Here's a short video of a GREAT night ride I had. Man I like these lights !!
[ame]
[/ame]
    • By OldATVowner
      any ideas how to correct
    • By T37Mark
    • By hunky
      Thanks for looking!
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
