My 2000 Suzuki quad king 300 4X4 starts great and runs great but after I drive it for a while it won't take it's gas and it won't move. If you turn it off it will start and idle fine til you give it the gas and it won't take it's gas again. You can turn it off and it will run fine again but it won't take it's gas again. This will go on for sereral restarts and finally it will run fine again, but after awhile of driving it will start this process all over again.Does anyone have any suggestions what it is
check fuel line, petcock and also gas cap and line out of it. if clogged you get vapor lock after a few minutes. not enough gas gets sucked into carb/engine then.
  • 4 months later...
Safety fuel petcock is the main fault vacuum operated fuel shut off bad fuel mixed with ethanol stuck choke cable my main was vacuum petcock will allow fuel into carb. long enough to starts backfire run out of fuel even tank full dealers charge anywere $112 part plus labor best is go online bangood.com 01 raptor fuel petcock $6.99 its two screws and a vacuum plug on carb problem solved also stay away from fuel with ethanol it sits week or two gums up your whole fuel system.
    • By Atomusthenes
    • By Memphis
      Regards
    • By Tim Keiper
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
