By Mikey509
By LMI
By colin james
View File 2017-2019 sportsman 450/570 with eps factory service manual
This is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
Submitter colin james Submitted 09/06/2018 Category Polaris ATV
By tds7
By shorty
FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
