remember im talking about something cheap.... since im 14 and have no job
wellll you shouldve metioned that :laugh:
i kno what you mean, i got lucky and had a lazy neighboor hood that doesnt like to cut grass haha
i dunno other than taking the racks off.
theres not many free mods for utes.
you can start with the air filter.
depending on which you choose thye will run you about 26$ to 50$
Uni air filters has one for 26$
Welcome to Uni Filter.com
here is a 2" lift 40$
eBay Motors: "NEW"- HONDA RANCHER 420, 2" LIFT KIT (item 330292312265 end time Dec-15-08 18:36:00 PST)
ask for an exhaust for xmas. here is an HMF for 230$
eBay Motors: HMF Utility Exhaust Pipe Honda Rancher 420 Black (item 380065838067 end time Dec-18-08 14:25:06 PST)
if u have the tools i can show u a bunch of stuff u can do at home... u can drill out a hockey puck and put it under ur shock and it will give u an inch of lift and prevent the front from sagging... u can build and underbody kit out if sheet metal some zip ties and a rivet gun mine came out pretty good overlapped the metal looks badarse...if u go for k&n ur gunna need a pre-filter i run that and it gives a good power gain... if u want to improve the sound on ur atv u can cut the tip off and their is a metal plate inside the exhaust that constricts the sound... drill holes inside of it and then weld a 2inch pipe at the end of it of the pipe this gives it a deep throuty sound.. i did all of these if u want the pictures except the exhaust gunna be doing that hopefully soon
Edited by outlander560
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By ebertz28
      Looking at 2 quads and need help deciding. #1 is a 2021 CF Moto 600 Touring with 69 miles, 2 seater with factory installed plow, windshield, backrest and luggage box with no warranty remaining  for $6500 or #2 2022 CF Moto 500 with 15 miles and a 2 year warranty for $6000?
    • By smipha
      Does anyone have a 2017 polaris ranger xp 1000 hunter edition service manual I can download? The one I have only shows things about the prop shaft for a crew model and mine in a standard. They have different shafts mine is cv not u joint.
    • By 95kingQuad
