2007 Arctic Cat 700 EFI NO SPARK PLEASE READ
Thanks in advance for any help or guidance. I was out riding the other day and lost all spark. I have read every thread on every forum that I could find and have not found an answer. I have checked the codes and its 00. I have ohm metered the stator and crank sensor. I have also replaced the coil pack. I have inspected and cleaned all connections. I do not mud the machine, it is mostly used at the hunting lease for working plots. When I installed the new coil I held the plug on the side of the engine and got 2 little sparks when first turning over and then nothing again. When you turn the machine over like this it eventually flashes EFI on the screen. I checked both wires that go to the coil and noticed that both have ground continuity. While turning over the blue and white one cycle from around 1v to almost 12v. The battery has a full charge and I am at a total loss. I took the kill switch apart and all looked well. Oh yea and all fuses are good. Help me please I am getting very frustrated. Thanks
it should be on the backside of motor ... looks like an oil sending type unit, probably 1 wire ... if the safety switch is damaged, its an easy fix, all it does is allow spark when in neutral ... i have seen some bikes that have a light saying they are in neutral and no spark, replace and spark again ... hopefully this is all it is ....
    • By justent_88
      OK, so I'm a boxing fan...anyone watch last night's fight between Manny Pacquiao & Ricky Hatton?
      The PacMan is just too fast and too accurate. Floyd Mayweather just announced yesterday that he's coming out of retirement to fight Marquez in July. Maybe we'll get a December fight between Pretty Boy and the PacMan?
      So, Manny has convincingly beaten up DeLaHoya (just announced his retirement from boxing) and now Hatton...
    • By Mhatayas
