My 1995, 425 magnum has a " whinning " sound when accelerating. Does not make the noise at idle or when reving the engine. Only when its moving. Is this normal ?
    • By canamKID
      Anybody familiar with this noise from my quad? Just started.  It temporarily goes away when I attempt to shift into another gear but shifting has gotten harder too.
      20260711_150338.mp4
    • By digrig
      Hey everyone,
    • By BillR94
    • By BillR94
      Thank you for your time
      Bill
    • By Kurt Reiser
      My quad will not run with the airbox hooked up  Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great  does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
