    • By mikeexplorer
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
    • By Matv88
      Bought it new for my son.  Pretty unhappy.  Very very very lean at idle.  Then there were a few things the dealer should have done during assembly including choke cable adjustment and rear brake adjustment.
      I'm going to drill out the tamper proof plug and adjust the idle/air screw to see if that helps.
    • By Rich1028
      Video from last Saturday on the Denton Trails...PONDS!
