After I rebuilt the card it seems to have a faster idle than before. I have tried to adjust the idle screw but will only speed idle up, not slow it down. What should I look for in adjustments. I purchased a card rebuild kit.
There are 2  screws that  affect the  idle .. The  idle  air screw and the  throttle  stop .   You adjust the  idle  air  screw to  get the  best  mixture at   idle. .   When  set right , it  will   have  close to the fastest  idle,  and  not stumble  when  you   open the  throttle.  The  throttle  idle  stop  is  just that .  It   sets the minimum throttle  opening.  That  is the  one  that   will  set  your idle  when the  idle  mixture is right.
Edited by davefrombc
Take another look at the position of the throttle cable and make sure the clip on the long needle is in the middle.  Those shuttles can be a little bit of a torture if the cable isn't connected properly.
    • By BillR94
      Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
    • By middlebrookgt
    • By Joeguy
      Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
      Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
    • By Louznmemind
