new guy
By mikeexplorer
By DayBreakJim
20230725_171507.mp4
By Ulfthednar
Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
This is from my side drive to the top of the property.
The Dog loves the runs.
No snowflakes were injured in the production of this video.
https://youtu.be/tKjBFuHCkM0
