Here's The Dilima
By Admin
Topics covered include:
AWD and differential repair
Brake system service
Popular related searches:
Sportsman 570 wiring diagram
By tepin
By Johnnynv
I recently bought a 2006 KFX 700 that had been sitting for 10+ years, started to replace the fuel system and the fuel pump has a connector that does not fit the same as original. The plug has opposite slot as original. There are two plugs on fuel pump bracket, some tiny sensor and fuel pump. The new fuel pump plugs in the same place as tiny sensor, where as the old fuel pump plugged into opposite position. I took old connector off bad fuel pump and repined it to new one, but now am questioning if this was the right thing to do. I did pay attention to wire placement but just feel like there should be a direct replacement. From the pictures on partzilla website, I cannot find a different option. Has anyone run into this issue?
By prdicon
Polaris it a bit cheaper.
Let's say 3-5 years from now.
By Admin
View File 2021-2025 Polaris Sportsman 450/570 1-Up service manual
Publication Printed August 2024 (PN 9941980 R01)
Submitter Admin Submitted 05/17/2026 Category Polaris ATV
