You need to test the charging system components, stator coil, regulator, the manual will tell you what the readings should be. A standard ohms test will tell you what’s going on. Also look for the easy stuff like damaged wires, blown fuses. Make sure that the battery itself is not bad also and that there is an accessory that’s not draining the battery. Plow ? Lights ?
Also:
You should have voltage on the positive and negative battery terminals when the bike is running without the battery in place and a tester clipped on to the battery leads.
    • By LMI
    • By tds7
    • By middlebrookgt
    • By sunn
      Anyone with experience on relocating the miniscule battery from the front lower center wheel area to the left rear wheel area on the Polaris Sportsman 570?
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
