  • 3 months later...
I would clean the carb first because of what @mikeexplorer said.  then try adjusting the idle screw, then the air mixture screw if none else works.  Wouldn't hurt to check the valve clearance too..but I would work on the carb first.  Does your bike bog down at any time when you push it hard or want to die right after letting off the throttle?  If thats the case, I think it would be running too lean- (mixture screw adjustment)
oh, and how does it start in cold weather?
    • By realpilot
    • By OldATVowner
    • By Mister907
