Did lots of looking at you tubes and checking prices, finally landed on the Bearclaw HTRs.  Found a set of 4 on Amazon for $396 when many places were almost $500.  I did look at going for 14 inch wheels like Ajmboy because they sure look cool but the difference in weight was not that much so reeled in my impulses and stayed with the stock 12 in wheels.
Thanks for the suggestions.
Nice, sounds like you got a good deal!
On ‎8‎/‎8‎/‎2018 at 12:36 AM, George Henry said:
I love Kenda tires!  Are the Bear Claws good in mud?
So far I am happy with them, and yes they are good in mud.    I checked out a lot of comparisons one you tube video tested the top rated tires and the bear claws did well.  I did check out the top rated tires and they were far more expensive.  I feel like the bear claws are good tires at a reasonable price.  I mounted them myself using a harbor freight tire machine.  If I was doing it again I would take them to the tire shop for mounting.  So far if I had to buy another set I would stick with the bear claws.  Hope that helps you.
That does help.  Thanks!
  • 3 years later...
