By rjsummer
By quadnut20
By Gtc4d
Thanks.
Todd
By jordan_ATV
By Louznmemind
I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
