New member, Alabama
bamaquad
Just letting my presence be known. Hello to all. I ride a 06 700 raptor set up for shorttrack racing. If anybody is interested in racing in the Alabama Quad Flattrack Championship Series which I started drop me a line.
Just started riding again. I did alot of motorcycle racing in Cali but haven't raced for several years. I have been in Alabama for a little bit now but I am definitely interested in racing my quad. Just bought a 06 YFZ450, I am somewhat new to quads but have been racing just about everything else since I could walk.
    • By NZrider
    • By jatho
    • By mkibbe
    • By jatho
    • By hardcastle
