I too joined this forum looking for a manual.  I joined to be a contributing member and not just "pad" my posting numbers to get a manual.  I poked around & found I like it here.  I made some posts and even started a club (Ride Red).  I also contributed photos & a service manual.  I am not here to be a lazy sponge.  Some people just don't get it!
  • Like 3
I found this forum while looking for a manual for a newly acquired sportsman 500 and decided to join after seeing diversity of the members. I would have joined anyway because of the wealth of knowledge and the eagerness to share. I agree with Ajmboy. A little participation is a small price for all the benefits here.
Thanks to all who contribute
    • By middlebrookgt
    • By remnar
      New member here,
      I have searched here and other places and have not found an answer to my problem.   As the title says I have a 2014 420 Rancher that recently started having an issue were the revs before the clutch engages.
      I have checked the oil level (per the service manual) and replace the Valvoline ATV 10w40(less than 5 hours) with 10W30 GN4 for good measure. I have used the "pin" method to pull a DTC.  I shows a 8-1 which is a TPS error.  This makes some sense, as if the computer doesn't read throttle position correctly, it could have this symptom. I have checked the source voltage, and tested the TPS off the quad with a Fluke and a power supply at 5v.  It is smooth and does not seem to be a bad sensor. I am confused by the DTC, because the PS light blinks the code, not the check engine light.  However, there are no PS codes of that value.   This condition appeared after a couple days of driving in the cold (~32°) and driving though some water/bogs.
      A couple questions.  First has anyone seen this issue, and do you have any suggestions? I have followed the troubleshoot right up to the point of replacing the ECU, which I don't seem to have one on the shelf :)
      Second, anyone used a OBDII reader with an a 4pin adapter to pull codes?  If so, what system do you use?
      Beyond the rev issue, the quad runs and starts perfectly and when it decides, the clutch grabs tight (no slipping)
      The first round of racing for the AMA Pro ATV and Pro Sport racers in the 2023 ATV Motocross National Championship (ATVMX), an AMA National Championship, was greeted with warm sunshine as the season kicked off in grand style within the high banks of the Daytona International Speedway. View the full article
    • By dirtdevil96
      I found a site that sells factory service manuals(type used at dealerships)and I thought I'd pass it along.They also sell some cheaper(inferior in my opinion)manuals as well. Repair Manual Catalog Online - RepairManual.com <--They had manuals for ATV's,motorcycles,lawnmowers,trimmers,etc.I've also seen FSM's available from Rocky Mountain ATV/MC I think this would make a good sticky;if the mods or admin would allow it...
    • By Machias_Mike
      Hi there!
      We just bought 4 acres and needed a work rig for moving stuff around and blazing trails. Been looking at buying a quad for a long time and finally got the opportunity.  Found a very good condition 1994 Kawi Bayou 300 4x4.  Runs great and seems to be in great operating condition with one little thing.
      The unit seems to have an issue with reverse.  Previous owner did tell me about it and its totally usable but the issue is annoying enough that I want to try and fix it.  Im pretty mechanical oriented so don’t think this will (hopefully) be too much of an issue.  I bought the kawasaki shop manual on ebay and should be here next Friday but wanted to get a head start on it.
      The issue seems to be similar to this post but I think may be more mechanical than just the switch.
      https://www.quadcrazy.com/atvforum/topic/14281-1994-bayou-220-neutral-safety-switch/
      Here goes!
      Neutral light is always on when key in on position I found that the green wire coming out of the block from neutral switch is grounded to chassis.  When plugged in to switch light never turns on no matter what gear its in (and wont start). Machine can go from 1st directly into Reverse if you don’t feather it.  This is the part that that makes me want to fix it.  I feel like its dangerous and could possibly do some damage.  It usually takes 3-4 tries to 'find' neutral.   The reverse turn knob seems to be operable and cable is connected and operates the reverse 'selector' when turned.  Springs back when released both at the switch and at the 'selector' inboard of the shifter. When in reverse the red reverse light does not illuminate Based on above and looking at the post above it seems that this would indicate that the reverse stopper is 'broken' and rotated in an 'in gear' position.  I see a few posts on here where people have said it can crack.  If I plug the green wire back in and turn machine to 'on' I can move the shifter through all gears and the neutral light and reverse light stay off.  Again, to me it seems that the 'reverse stopper' is probably broken, stuck where the switch thinks its in a forward gear and the shaft is probably just spinning inside it.
      Am I on the right track here?
      I wanted to get a head start on this and looking at parts diagrams it looks like the part number for the 'reverse stopper' is 13091-1443, found one on ebay for $30 shipped.  I hate buying parts before tearing it down but if this is the likely culprit I would take a $30 gamble to buy it so I can have it on hand when the manual arrives.
      The other question I have which I hope is an easy answer is none of the parts diagrams I have found show the bevel gear gasket part number.  Can anyone tell me what the part number is for this?
      Many, many thanks for the info and I promise to post pics once I have it apart.
