piston 1995 Polaris scrambler 400 broken piston skirt and bearings can't get the clutch off my atv
By
Bobby Belmain, in Polaris ATV Forum
Similar Tagged Content
By JacobSlabach
Hey just picked up another scrambler 850 was told the tps was bad. This atv has been beet to hell. Wiring has been tinkered with the crankcase has been replaced recently and the motor rebuilt (can see horizontal scores thru spark plug hole where it’s just been honed out and rebuilt)
my guess is it was ragged out till the motor blew a rod and rebuilt but the clown that did it couldn’t get it to run again and sold it. When I bought it it would pulse and smoke black at idle and die with throttle.
New tps installed and it won’t run period. I went to celebrate it and I’m getting 5 volts on 2 of the 3 wires running to the tps. Is this normal and if so how should I celebrate it?
By JacobSlabach
Hey so i sold my 04 rubicon and wanted something new so i went to NC and bought a '13 scrambler 850XP LE EPS. love it the only issues with it when i bought it were a leak in the front tire and the mice had chewed through one of the spark plug wires. currently have a substitute hooking the chewed end to the ignition coil so itll run on both cylinders however im having an issue finding a replacement coil wire for it and was wondering if yall had any advice. i need the longer of the two coil wires and i can only find the shorter one online. will throw up some pics of it when i can
By Brian Simmons
The battery was gone when I bought the 90 .There are 7 wires 3 red 1 white ,1 black , 1 green and 1blue . 1 red and 1 white are connected with connector like it`s suppose to go to the battery . I think it`s called an eye connector it`s round and has a hole in the center . So it can be bolted to the battery and the same with the black wire the one black 1 has a connector on it that looks like it goes to the battery . that leaves me with 2 red wires , 1 green wire and 1 blue wire !!! Can anyone help me with a diagram of how the wiring goes to the battery on my 2002 Polaris Scrambler 90 ??? Please help me with this my e-mail address is [email protected] Pl
Please help me with this . Thank you , Brian
By Aaron Ruiz
Hey I'm new to the Forum but I just wanted to talk about my Scrambler I just picked up and when I first picked it up I thought it was okay but after I got home and everything I noticed it's very hard to shift into drive neutral reverse it is possible to shift into those gears but it's very stiff like and it takes a lot for it to actually engage to move forward. In Drive when I press on the gas it takes a while for it to actually start moving in the RPMs go up before it starts moving I inspected the belt it looks fine to me I checked the transmission fluid and it was low so I put some. I just hope transmission is not out just curious if you guys have any ideas
By Derrick Lenz
So I have a 1999 scrambler 500 4x4 and whenever I give it throttle it starts to big down and when I let it off it dies. Its getting spark and fuel. I replaced the fuel pump. The petcock, the carb, fuel lines, fuel filter. And for electrical I've replaced everything but the rev limiter. I took the srv to get it worked on and the guy set the jets and everything on the carb to where it should be and still no luck. The contacts on the ECM are also not touching. Any help would be greatly appreciated. Thanks
Similar Topics
By Gsk1500
The clutch cover goes on and fits, but the little L chapped arm that has gear slots is concerning me. It appears it goes to wear the clutch adjust bolts are on the cover.
Is there a specific way to tell how it mounts on the gears in relationship with the basket?
I don't want to deal it up unless it's right
By Gsk1500
My byou finally got running after I rebuilt the carb. I took it for a trail ride, and finished by riding her pretty hard up a dirt hill. At the peak of the hill it dropped out of gear, and had to be pushed home. It will still start, and idle. When I apply throttle it revs really high, and no matter what gear it is put into, it will rev high and take a few moments after i release the throttle to wine down.
I have pulled the clutches out, and it does appear the centrifugal clutch is worn. I took the dremel to it, and tried to get some relief lines back in there.
Before I reassemble and test, does anyone know if this is even a clutch issue? or possibly transmission/case related.
also can I make a gasket out of cardboard and Indian head just to test after cutting grooves in centrifugal clutch?
By xXDaveXx
https://www.amazon.com/Primary-1998-2005-Polaris-Sportsman-Braking/dp/B01G2EEUV2
Anyone ever try these? $500 for a OEM clutch seems high, But $120 seems a little cheap to me. Has anyone tried one with good luck?
By JacobSlabach
got 7 atvs off CL recently for a good price. one of which is a yamaha warrior. anyone know where the vin is printed on this bike? Haha good place to start as I do not know year or size yet. The former owner says needs exhaust ans and clutch work. he said it ran fine until the clutch cable broke and then I couldn't get the new cable adjusted right and it would grind gears. things I see: clutch cable locked up again, no brakes, carb leaking (green with algae around the bowl and has gelled gas stalagtights on it), aftermarket exhaust melted the airbox so I need something different and a new air box. I would like the use the current exhaust if I can but I have a feeling its a redneck fix as it looks like there is an ace bandage holding it to the exhaust pipe (its an aftermarket slip-on exhaust), so I'm not sure about that- lets get the bike running first. also, battery (looks brand new, what a shame) is dead, 0 volts. Otherwise, bike looks to have not been wrecked, and plastics are ok (it sat outside under a 'tarp' for 3+ years since it was run last). any tips and advise on where to start first would be awesome as this is my first clutched bike (manual).
the clutch is my main concern- I've never rode a clutched bike so I dont even know what its supposed to feel like. lol I'm spoiled on my automatic polaris
By Ssg
Hello! This is my first bike with a cvt it's a 19 Outlander 850 xmr. I use the 30" cryptid tires that come with the bike during hunting season since I hunt in a louisiana swamp and I have some 27" interco reptiles during the summer trail rides. So this past hunting season I got stuck and squealed the belt do i looking at cluch kits /adjustments to help with the low end but I dont want to mess with my summer riding so I'm looking for advice
