  • Ajmboy changed the title to ATV Carburetor Tuning How To
Screw the needle all the way in, then back it out 2 1/2 turns out. This should give you a starting point. Start the engine and slowly adjust until runs decent.  If it won't start, back out 1/4 to 1/2 turn at a time.
      Hello there
    • By p5200
      Hello, I'm getting ready to replace the carburetor and was just wondering, will I have to adjust the air screw on the new carb? Thanks! 🙂
      I Ran across this video today comparing an aftermarket to OEM Carb on Suzuki Vinson, thought it might generate some interest, it is quite long but informative.
      I got my no spark issue sorted out, got it running on the old aftermarket carb, but it didn't want to take throttle even after cleaned it, didnt really want to waste time on it, so I order a new one which is on its way, so not much to post here, but I wanted to start a new thread. I am stating to clean up the plastics thought I might as well do that while they are off, they were a mess tree sap, bird dropping, mold and what ever. Washed them good and got all off so I could see the oxidation , decided to wetsand with 600 grit waterproof sandpaper, and used Armour All instead of water. I figured it could put some of the moisture back in that was lost from sun exposure.
      Working fairly well I will keep going finer on the grit and see if it will polish
    • By Charly007
      Need to know where lines on bottom of breather box goes and any on carburetor
