    • By Shorty51
    • By fixitforfree
    • By dlw
      i have a 2016 kymco uxv 700i and i am having issues with transmission. it makes a horrible noise in 2 wheel and wont move. it will move in 4 wheel but still makes noise. has anyone had this same issue?
    • By ericggg
      Hi, all
      I have a 2010 Honda try 420 at and I'm having an issue with the transmission.  Every now and then the while riding the transmission goes into neutral or stays in gear high or low.  Recently while riding it stayed in 4th gear, had to come to a stop and rock it back and forth and it want back to first.  Did any one have similar issues and what can be the diagnosis to this problem and is it worth fixing.  I called the Honda atv dealer and told them what happened and they said it's going to be $2000-$3000 to fix that seems crazy.  Any help or idea will be greatly appreciated.
      Thank you all
    • By p5200
      Is this safe for the 2005 model? I know some have used it in the 2000 models. 🤔
