I have been working on a 2004 arctic cat 400 that will run for a while with a new coil installed then after a few min start sputtering and quit. Checking the coil afterward it it is burned up. There is 350 Plus volts going to the coil and I'm not sure if I need a CDI or its something else? Flywheel magnets have been ruled out!
  • Admin changed the title to 2004 Arctic Cat 400 has high voltage at coil
  • 3 months later...
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By Mister907
    • By tepin
    • By HoldenBoy
      Hi all,
