Little taotao's
By DexKing
Good day everyone!
I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
By HeWasRidinDirty
By jeffrocdx
By Maddman200
Who agrees with me that Yamaha atv quailty was one of the best well built quailty machines money could buy, then 2007 came rolling in and they have gone to complete sh**. Cutting corners everywhere they can and made such unreliable machines
By alexwv1863
I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
