having an alignment problem with the machine pulling to the right,  it has new tires, no apparent wear on the steering components or damage.  Does anyone have any experience aligning these machines?
  • Admin changed the title to 1999 Suzuki LTF 500 Alignment Problem
a locked up wheel bearing can pull your bike right off the trail-  was riding with a buddy on his old sportsman 500 and one of the stock front wheel bearings locked up seizing that wheel.  had some trouble getting the quad out of the ditch..........  fortunately we weren't going super fast so nobody got hurt..
if the quad has ever been run into something, that can bend something and you just have to adjust the tie rod.
ok.  first thing I do when a bike isnt headed the way the handlebars are pointed is get the handlebars straight, get off the quad and stand back from the front of the bike and see if one or both tires are pointed off the one side even a little.  otherwise, I would check tire pressure, shocks, bearing... anything that would make one wheel roll different than the other
    • By noticon75
    • By toe420
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
