2000 yamaha kodiak 400 2 wd start key turns blow 10 amp fuze
By Fonne
Hi
What machine would you recommend ? - Really want a solid machine since I am no mechanic but can perform a early service myself.
By prdicon
Polaris it a bit cheaper.
Let's say 3-5 years from now.
By sandman001
By quadnut20
Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
By Rockbottom
anybody have a electrical drawing
cant figure out problem
new starter relay, when i turn the key on all 3 leads to relay are hot red, blue, blue white. Is that correct. nothing happens ir clicks at the starter relay when i push the start button
on the relay closest to the cdi and nearest the brake light the relay vibrates as if it is opening and closing rapidly
the batter is new and good
if i short the B and M lugs on the starter relay the engines turns over but does not start and there is no spark
I ordered a new cdi but the one on the machine is only a few months old but a aftermarket
anybody have a electrical drawing or advice ir know what that relay symptom is and what activates it
thanks ahead
