Have a 400 4×4 have cleaned carb niow when u start it u have to have choke on and when u kick the choke off the engine speeds up then dies like it's not getting fuel plz helo
Edited by Ajmboy
Added ATV info into topic title
  • Ajmboy changed the title to Polaris 400 4x4 Idling issue
Have you checked the fuel from the tank to make sure your flowing? Shut off valve, filter or screen inside the tank if there’s one? The fuel air mixture screw set properly? What did you set it at?
If all above is good then sounds like a typical cleaning that was done but something was left behind. Go back and take the carb off, open it up and double check everything!  Make sure your reassembly of the choke was done correctly, the float was set at the proper height and the the fill  needle that allows fuel to enter the carburetor connected to the float has no junk in the port or on the needle itself.  Blow all the ports out with a little air pressure.
When an engine starts to rev up it’s mimicking a choke condition starving for fuel.
Not saying you did a bad job but sh** happens. I’ve done it and gone back before to find out that when I put the carb back on it worked fine.
  • 2 years later...
    • By Mister907
    • By Brent Wright
