i wired to the winch feed that comes right from the battery. i went throuhg the switch to the light bar with AND without a relay. both time i get code C1326 on the dash and loose my EPS. what am i doing wrong? should i be feeding the bar and switching to ground? i just installed a new battery the dealer said will fix it and same problem C1326. $120 wasted again at the dealer. why can't i talk with the mechanics at these places? sales people know little about the new machines and just smile at my wallet.brand new machine by the way too.
  • Ajmboy changed the title to Textron mudPRO 700 led light bar install?
I was going to say to go over it all again and bench test it before you wrap it up again. Maybe give it a direct feed from the battery with a fuse.
The wires on the switch are only interrupting the red wire without the really and with the relay your sending 12 volts to the relay to bring the relay in correct ?
Yes I do. I think the bike is picking up stray voltage. Most of the lights have a diode built into the lights.  It’s a check valve if you will for electrical. Allows the flow of electricity to go only one way.
That would apply to the older bikes.  The newer bikes are much more intricately designed with regard to electrical safety. So adding anything to the wiring adds an amperage draw to the system which is outside its normal draw and will throw a code out onto the dash. It will also lock out the ecm.   This way no wires burn up.
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
    • By crankin
      any ideas how to correct
