So we disassembled the head and jug and the piston. The rings were stuck...after soaking for a while we were able to get them free and cleaned them up good. Also cleaned the seats in the piston and lightly sanded with 1200grit so the rings are nice and smooth.
Oiled everything up and in the process of putting back together. Fingers crossed.
I guess compression is a wonderful thing...cause she runs! Gotta get the valves adjusted a bit...she kinda taps right now but she purrs and not much smoke... thanks everyone for their help.
Now to change gear oil in diffs and get rear brake adjusted.
    • By sandman001
    • By marlon smith
    • By kevinohio
