Join Today, It's Simple and FREE!
Similar Topics
By Mike Johnson
Does anyone know what the 3rd item is behind the battery on this ATV ? I know 1 is the, solenoid1 is the CDI box, what is the 3rd.
By Dwight Williams
Ok, so I bought a 2006 bayou 250 for 200 bucks, kid couldn't start it and had no idea why it wouldn't run, I pulled the rope and felt what I thought was valve to piston contact, he wanted 500 and I talked him down to 200 and brought it home. Sure enough, timing was way far out, timing chain incredibly loose. So for fun I re-tensioned the timing chain and re timed it, got about 120lbs of compression, pretty low. I cannot get the chain very tight but the the tensioner seems to work fine, the chain guides don't look very worn. Also, when I took the head off the valves don't look bent and the piston has no discernible marks on it. Is this an interference engine? I sure thought I felt some contact with the pull rope but maybe no permanent damage was done? Anyway, I plan on doing a full top end job as well as timing chain tensioners and hopefully that'll cure it. Is there any reason other than chain stretch (I measured it and it's ok) or guide wear that would cause the chain to be so loose? Thanks!
By Daniel Gibson
Working on a bayou 220 that has been ran extremely hard it's whole life. Literally had almost an inch thick dirt/oil covering the motor. Yeah that bad. Surprisingly it runs though. I cleaned the carb and tank multiple times. They're clean enough to eat off of. Readjusted valve lash and set timing. Was about 3 teeth off. It cranks good and runs good only problem is I have to cover the carb intake basically choking the hell out of it for it to start. The com choke works fine. It does this each time I start it regardless of temperature both ambient or motor. Wth? Compression is at 115psi I get 130s if I put a little oil in the piston chamber. Please help. Thanks
By jake Stillman
Hello I am new to this forum and lt80s I have an 87 that has burned up 3 coil/cdi combos my question is can I out the newer set up on it and if so how do I do it I know they have different number of wires going to the cdi mine only has 2 please help
By Jeff Comstock
Ok, so I had no spark issues and foundy coil was bad. Bought a caltric coil, put it on and fired right up...for bout 20 minutes then it backfired once and again, no spark. I put it on my buddies 300 and it runs. Checked my cdi the same thing, but still no spark. Now I got my old coil and was ohming it and got reading of .01 on primary and 11.89 from POS to plug ( meter set on 20k ) new coil reads same primary but 12.83. what gives? It tests bad but runs my buddies 300, helllllllpppp
Similar Tagged Content
By Mike Johnson
By Andrew Baker
I need help with wiring on a 1998 (I think, 10th digit of the VIN was W) Bayou. I'm not getting spark, I'm pretty sure it is due to grounds being off because the harness is pretty hacked as far as the electric start and charging system goes. I'm needing a good wiring schematic. I found one online and there are a few things that don't add up on it so I'm skeptical that it is really for my year and model. Any help would be appreciated. Thanks.
By Gary Skriba
just got a 99 Kawasaki bayou replace the coil because the spark was very weak still have the same issue before it would start after a while that it would start everyday as long as you started it every day but if you let it set you play hell starting it looking for information on what could possibly be wrong maybe the CDI box not sure any help would greatly be appreciated thank you
By Ben Lennon
Hi guys new to this forum and thought I’d jump on as I’ve just bought my first quad a Kawasaki bayou klf300c 89 model. It had starting issues when I bought it so I’ve gone thru and replaced the cdi, voltage regulator and starter solenoid aswell as rebuilt the starter motor after all this it was still free spinning on electric start so I pulled the stator cover off to find the fly wheel wasn’t spinning so replaced the one way clutch bearing put it all back together and still not engaging at all. I’m at a loss and looking for some ideas on we’re to look next to solve the problem
cheers Ben 👍
By Jeff Comstock
Help a brother four legger out
Bayou300 acts like it's flooding if it's it's in the Alabama sun all day but, I've cleaned the carb. Sometimes it'll backfire even though the timing and valve lash are in spec. Thought it was sticking float but after 2 times cleaning the carb I'm lost. So
