5 hours ago, Frank Angerano said:
That’s great. Hopefully this is the last bit of what needs to be done and you can get some riding in !
Ya, the thing fires up with just a touch of the button!
I'm nursing a bum leg that I messed up a couple weeks ago. About 5 of my buddies went riding today, but, I gotta pass until the leg is %100. The weather is freaking perfect too! 😧
  • 5 weeks later...
On 9/30/2019 at 5:36 PM, Frank Angerano said:
Let it heal! Plenty of time to ride later.
Glad it’s running good, ride safe.
Well the 400 crapped out on Saturday. I took a look at it yesterday and this is what I found. Sheared the key right the f*** off! 20191029_160502.thumb.jpg.b90caee492f1b5c109fd097f31d85b1c.jpg20191029_161103.thumb.jpg.a8e3c9addcf238b057a6d638c3e92796.jpg
On 10/30/2019 at 6:28 AM, Frank Angerano said:
Holy crap. The the engine come to an abrupt stop or back fire at all ?
It just stopped. I got it back together and fired it up. I had a dirt bike that did  that outta the blue. I fixed it then it did it again in short order. My buddy suggested to put valve grinding compound on the crankshaft and put the flywheel on and spin it, spin it........ so I did that and it's been good ever since. So, I did the same thing on the 400. We'll see how it goes!
The flywheel is supposed to be installed clean and dry - looks like the taper was greased or smeared with anti-seize - the key does not hold the flywheel - the key is to align the flywheel to the crankshaft so it is in time - it is the taper that locks the flywheel to the crank - if you don't get the flywheel properly torqued, it will shear the key in a short time.
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
