By p5200
By Gwbarm
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
By BillH
Hi all thanks for having me.I am currently having problems with my steering system on my Hisun Forge 450cc.
It is very hard to steer and is stuck in 4wd or diff lock.
Any ideas on how to work out what is causing this.
As I tested the bike and it is definitely stuck in 4wd.
Thanks guys
By JGou
Have an axis 500 bought from Lowes.. Have had to adjust the shift linkage 1/2 doz times in the last year.. Now the UTV is stuck in neutral.. Seems to shift ok through gears but neutral light never changes, and wont move at all when running.
Only have 13 miles on this 4x4 and have had no other problems... Any help would be greatly appreciated.. Thx, Jay
