Hi guys new to this forum and thought I’d jump on as I’ve just bought my first quad a Kawasaki bayou klf300c 89 model. It had starting issues when I bought it so I’ve gone thru and replaced the cdi, voltage regulator and starter solenoid aswell as rebuilt the starter motor after all this it was still free spinning on electric start so I pulled the stator cover off to find the fly wheel wasn’t spinning so replaced the one way clutch bearing put it all back together and still not engaging at all. I’m at a loss and looking for some ideas on we’re to look next to solve the problem
cheers Ben 👍
Hey frank I didn’t replace the bendix just put a brush kit thru it. And looking again last night the starter sprag gear and chain from starter is spinning  it’s just not engaging the fly wheel. Could it be that the bearing race on the fly wheel for the one way starter bearing is worn and that’s why it won’t engage?
The  sprag is a clutch.. It  is a special assembly that  locks up in one direction and free wheels in the  other. I don't know about your machine  but on many the sprag  can be  put in  wrong side out  so the starter can't  lock it up to  turn the motor over. They are built  with   rollers  that  are made to lay  flat when spun  on way  and   rotate  to  lock to the  outer  part when  spun the other..  Search on "sprag clutch"  to  see what I mean.
Edited by davefrombc
  • 4 months later...
    • By Jdeaton011989
    • By HHurks
      Thank you!
    • By HoldenBoy
    • By en4cer
      Problem number 1,
      Problem number 2.
      Any help would be nice.
    • By DexKing
      Good day everyone!
      I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
