So my latest find is a Moto 4 250. Looked in good shape, started right up but would backfire and die upon acceleration but you
could get it to go if you were good with the throttle. I figured it was the carb. was a brand new Chinese carb, he didn't have original.
I took it apart and cleaned it, only thing I found was some debris in main jet and the main adjustment on bottom was at 41 turns. Cleaned
it out and set at 2 turns, re installed. Starts up, runs better actually drove it but seems really sluggish, once I hit 3rd gear could barely pull
it. Rechecked everything, even ordered a new carb as I had this problem with another atv but still same problem. Now I pull it apart and
decided to check compression, I show only 85 psi. I checked valve adjustment (after aligning up cam gear to mark on case). to make sure not too tight still right at 85 psi.
I assume I need to pull the head and look at the valves, Any ideas I am missing something?  motor does not smoke but is super sluggish.
The specs I find are off the downloaded manual of a 94 but figure should be the same. It states compression standard is 128  and Minimum is 114 and Max is 142
Any other Ideas before I tear it down? Thanks in advance Az
Well was going to tear it down today but double checked a few things
rechecked compression, right at 85psi then rechecked compression with
throttle wide open and I get 125 psi. Double checked and confirmed with throttle
open 125 psi. so I assume the motor is not the issue.  Still looking at the carb as it
feels like a carb issue. Similar to problems with the Kaw bayou 300 I had. So gonna
set the valves before I put it together, Since I don't have original carb and have tried
2 Chinese carbs, should I try a jet kit and install in this carb? If so what ones do you have
the most luck as far as accuracy with?    Might also see if ign. coil is putting out enough
volts, I am assuming it should at least put out 20kv Any other ideas? Thanks Az
Hey Az, if I’m not mistaken and maybe a few others can correct me if I’m wrong but the  compression reading should not change wether the throttle is open or not? The compression reading is contained at the top of the piston stroke so the only place to loose it would be valve seals, head gasket  or ring wear and not opening the throttle.
 If you have the oem carb then tear it down and go with a kit, oem size jets obviously.
I’ve used a few different  types. I like the Hi-Caliber brand, $35 bucks on Amazon. So far so good with them.
Yes the compression changes every time I either open or close the throttle.
 Never heard of
the readings changing with throttle angle. It will read 125 as long as throttle is opened.
If not it reads about 85psi. The motor runs super smooth at idle and doesn't smoke.
Any ideas what I should do with it or just leave it alone?  Now second thing. I do not have the
oem carb. Should I try the jet kit on the new Chinese carb? or wasting my money? Az
Edited by Arizona
add pics
Wasting money on the jet kit with a Chinese carb. I would rather try to locate a used oem carb on eBay and try my luck and at worst it will need a cleaning maybe new jets. The only reason I can think of that the compression reading keeps changing is the cam lobes are worn down and there is not enough intake based on valve lift ? Throttle movement should not change the psi on the gauge as far as I know.
Strange but maybe @davefrombc or any other members can expand on this a little.
I agree weird readings. But they are repeatable. Just depends if throttle is open or not.
Would think cam problems would be constant. I cant think of anything that would make
them change due to throttle angle. Im stumped. Any Yamaha motor builders out there that
have ideas?
On a second note, after screwing with the second carb I got it to go quite a bit faster but still not right.
I can floor it in neutral and it wont redline. Just revs about half of what it should be. Pretty odd as it
idles pretty smooth and starts pretty easy. Hoping for some knowledge on the motor Az
talked to an atv engine builder and he said you will get different compression readings
between no throttle and full throttle. Should be checked at full throttle. I checked the online
manual and it says check at wot20191010_175945.thumb.jpg.a013fc8caaf6aa9c635aae8bbd9211f1.jpg
I would assume that as the piston goes down and takes in air through the intake with an open throttle that allows more air intake thus more volume and more to compression on the way back up .  Makes sense now never thought about it really.
Well im looking into a used oem carb. The online engine builder says he has a few and should call me back.
also found 1 on ebay but looks pretty rough. Ign. coil was putting out about 28kv
I sure find the weird ones! Az
Lol yes you do. Me too though, my guess is that people do crazy sh** to there bikes OR it’s a broken bike  and everyone and there mother’s are “mechanics” and try to fix them and tear into wiring etc.
Although this is a hobby it  also takes some brains to work on this type of sh**.
Just got a 1991 Yamaha Moto 4 YFM250 for my kids and have some basic maintenance that I know needs to be done and am somewhat new to ATVs, so any advice is much appreciated.  Thanks for all the detailed info about yours.
    • By WeeBee
    • By Elk
      2002 Polaris Magnum 325
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By DrtyGrlKristin
