If your sure your getting spark then spray a little starting fluid into the carburetor intake while cranking and see if it starts.  If it fires up then it’s a fuel issue. Could need  cleaning of the carburetor OR the fuel flow is not coming from the tank.
Start by pulling the fuel line off of the carburetor and verifying that you have fuel flow from the tank with the petcock open.
if that’s good then the carb has to come of and be taken apart/cleaned out.
But before you do all of this make sure your gas is good and your spark plug is new and not fouled up.
  • Admin changed the title to 1987 Honda 350 Fourtrax will not start
On 10/10/2019 at 11:58 AM, spock58 said:
By all means try all the suggested tests but don't skip one of the most important ones: do a compression test!
Got it running.  We gas and had to prime the heck out of the new carburetor!
thanks all!!
  • 2 years later...
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
