Testing help for coil on 99 bayou 300
By 88bigbear
By cfherrman
By LashinWheeler
Any help would be great,
Thanks!
By hengstserepair
Nuetral: Runs as expected
Lorne
By TomJulio
My 1992 TRX00 recently stopped firing. I understand this is a common problem. I have ordered an aftermarket CDI unit. TJ
