Hi guys im new here and ive been doing alot of research on my polaris predator i was wondering if anyone on here has wired a different cdi up on there quad? Not a direct replacement that would simply just plug in. I know my white an w/red wires go to my pulsar my green an blue go to my reverse coil but im unsure which is + and which is ground also brown/w is a ground correct? What about purple? Black goes to my kill switch and red is my 12v supply........then ive got yelloww/red , yellow / yellow that goes to my rectifier..........any input on this subject is greatly appreciated thank you all
  • Ajmboy changed the title to 2006 Polaris Predator 500cc CDI Wiring
I have the 2003 manual i thank you for your time and its nice to be a member of the site...........the two years are different cdi's the 06 has 1 extra wire the 03 was 8 pin the 06 is 16 but only 9 pins are used. I have a cdi and harness from a sawtooth im trying to keep the pred with its original harness and just incorporate the sawtooth cdi i know it can be done. All cdi boxs do the same thing some are just ac and some are dc which is what the pred is. Ive got a cpl other cdi's but i think the sawtooth is my best bet. If i was rich id just buy a oem unit but i dont got it like that unfortunately so i gotta try and get by with what i got! Any input or ideas on this i encourage an thanks once again ......
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
