Agreed so even more of a reason to order two gaskets and the starter clutch.  Its always better to have then to need!
I ordered a second gasket and will need to shop around for the one way bearing I think.
2 hours ago, Frank Angerano said:
Have you priced it ?  Should be no more then $60 bucks and a lot of them come with the gasket.
The OEM is higher priced so I ordered an aftermarket with bolts for $28. https://www.ebay.com/itm/Starter-Clutch-One-Way-Bearing-Sprag-For-Yamaha-5Lp-15590-00-00/291688226787?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
I have two gaskets coming so I'm going to put the aftermarket in with the existing gear and see how it goes. If it doesn't last, I'll open it up again and replace with OE and a new gear or get an aftermarket kit.
I also ordered an OE oil pump chain because I think mine is stretched: https://www.ebay.com/itm/YAMAHA-CHAIN-2002-2008-YFM660-GRIZZLY-2004-2008-YXR660-RHINO-94581-94070-00/273490598260?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
I didn't have a puller around and ordered this one for $24: https://www.ebay.com/itm/Tusk-Flywheel-Puller-Remover-35mm-YAMAHA-GRIZZLY-350-400-450-550-660-700-rotor/172483117628?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
@Frank Angerano Thanks for your offer on sending the puller but shiping there and back, it was worth to just get one and have it on hand part of my "collection" 😁
Absolutely welcome brother.  Looks like you ordered the right stuff! I agree with throwing the new gasket on but just spray carburetor cleaner on the one way clutch and clean it good.  I think fresh oil and and you will be good to go. Worst case it acts up and you have the new one on hand.
I haven't even started to put this back together yet. Got shifted to other projects like landscaping....and because walmart hasn't sent me my oil, I now have to run out! I ordered it on April 9th and still delayed...
So I decided to also order it for pick up and will probably run out Friday or Saturday because I need to go to a bunch of other places...was trying to avoid going to the store unless I absolutely had to and they have the best price...with corona its a process...mask, gloves, disinfect everything, shower 15 times...
Hopefully back together this weekend.
Figured I’d replace the bearing now than in the winter if it goes. Replaced the oil pump chain but the old one and new had same amount of play so probably didn’t need to do that....
Got the flywheel off and couldn’t find my 6mm allen socket to take off the bearing, so ran to Lowes and bought a metric set. Go it off and went to put the new one on and realized it’s wrong! I must have messed up in my searching on eBay and bought the wrong one. Cleaned the old one and reinstalled. Put it back together and fired up after cranking for a bit after messing with the choke, almost like timing off but then started. Still need to put antifreeze in it, no way to do it without disconnecting coolant hoses.
I cleaned the bearing and inspected. We’ll see how long it lasts. At first when it wouldn’t start I thought maybe I messed something up. I’ll get back at it tomorrow hopefully.
So didn't last long at all, started doing the same thing. I've been waiting for part from Rocky Mountain for a week. Have to take it all apart again and replace that starter clutch. I also ordered a new battery from batteryclerk.com. Got it in 2 days.
    • By Randomnumber73
