That would work if rebuilding the diff, but I misunderstood what you have that needs fixing. I updated what I said above to reflect just replacing the axle bearings. I completely forgot there are bearings and seals at the ends of the axle on a Bayou. You'll need a blind bearing puller if you want to try without pulling the whole rear axle apart. And I don't know if that works for sure.
Yeah, the guy in the 2nd link has it figured out. The guy that pulled everything was doing it by the manual. A manual always does it the hard way so you can check everything while its apart. I like the easy way.
@MarkinAR, thanks for the tool rental idea. I hadn't thought of that. I was able to rent (temporarily buy) a slide hammer and a claw type attachment from the neighborhood O'Reilly auto parts store. I started on the right side bearing and it only took a dozen or so medium pops with the slide hammer and the bearing came right out. I removed the seal and replaced the seal and bearing, no problem. (See my 2nd youtube video above starting at 3:30 to see what I'm talking about here)
I moved over to the left side and hooked up the slide hammer just like the other side. I gave it increasingly harder hits with the slide hammer and got zero movement so I ended up taking the left side axle tube off. After removing the seal and cleaning it up a bit, I found the problem. There is a big snap ring there. A better pair of snap ring pliers probably would have made removing that a quick job but I managed to get it out with my cheapies and a small screw driver. Putting in the new bearing and seal and putting everything back together was easy enough. One more job crossed off my list.
If anyone is looking at a rear wheel bearing job, I highly recommend the slide hammer trick. All you need is the slide hammer with the three point puller attachment, a 3/4" washer (don't want to mess up your hub nut washer), and a pretty nice pair of snap ring pliers, plus the normal tools you'll need to remove seals and seat bearings and seals. I used a socket to seat the seals, the old bearing to hammer on to seat right side bearing and the bottom of a trailer hitch ball for the left side bearing.
On 5/11/2020 at 6:28 PM, 1911Neil said:
I ended up just buying this. Should have it by the weekend.
Where did you find that connector and the terminals? Gotta link. Thanks
https://cycleterminal.com/
Fast shipping and I think he sent like 7 connectors in case I messed up a couple.  I used one to replace a connection on my neutral safety relay.
I hope posting links isn’t against the rules.
    • By mehim
    • By logray
      Hi all,
    • By joshualutz
      so we got this little lt80 given to us when we bought my sons dirtbike as kind of a throw in gift it was just sitting not being used and my youngest fell in love with it so the gentleman we bought the bike from said we could take it as well for a little project
    • By USRaider
      Hello all!
      Kept indoors but hasn't been run in 5 years.  We're not trying the engine until the gas is replaced, and the tires are reinflated. But the previous owner said their only issue was stalling when shifting to reverse without giving some throttle.
      I'm optimistic!  See y'all around!
