To me. Sounds like it’s jammed up. Does it roll in gear? Can you select gears while it’s rolling? Does it run if you jack up the drive wheels, or at all?
Any grinding of gears? Sounds like one of 2 things. Either a clutch kit because it goes into neutral when off. Or a blown gear. Be more in depth on your description. Can you shift when it’s off and not while running? Or what happens when you have it in gear and try to start it? Many factors can happen.
    • By marlon smith
    • By wilmpie
      hi everybody
      I have a kymco mxu 250 automatic from 2006 250 cc  that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
      if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
      what can it be or what can i do to fix this?
      thanx in advance
      p.s. Sorry for my bad english it's not my first language.
    • By dkgg5755
    • Guest
      By Guest
    • By T37Mark
