To me. Sounds like it’s jammed up. Does it roll in gear? Can you select gears while it’s rolling? Does it run if you jack up the drive wheels, or at all?
Any grinding of gears? Sounds like one of 2 things. Either a clutch kit because it goes into neutral when off. Or a blown gear. Be more in depth on your description. Can you shift when it’s off and not while running? Or what happens when you have it in gear and try to start it? Many factors can happen.
    • By OldATVowner
    • By marlon smith
    • By wilmpie
      hi everybody
      thanx in advance
    • By dkgg5755
    • Guest
      By Guest
