Hey so i sold my 04 rubicon and wanted something new so i went to NC and bought a '13 scrambler 850XP LE EPS.  love it the only issues with it when i bought it were a leak in the front tire and the mice had chewed through one of the spark plug wires.  currently have a substitute hooking the chewed end to the ignition coil so itll run on both cylinders however im having an issue finding a replacement coil wire for it and was wondering if yall had any advice.  i need the longer of the two coil wires and i can only find the shorter one online.  will throw up some pics of it when i can
About any coil wire should work that is long enough.  Usually you can unscrew the plug boot and unscrew the wire from the coil and replace it.  I've used skinny auto plug wires before.  Anything that will fit into the plug boot and has a good thick silicone shield.
good investigative work!  I use Babbitt's or Partzilla to find the part number of what i need and then search ebay, amazon, etc and usually find it quite a bit cheaper than dealer.  Just have to dig through the diagrams and find what you need.
  • Ajmboy changed the title to 2013 Polaris Scrambler 850 PTO vs MAG Ignition Wires
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By cruteg8
      View File 2020-2026 Polaris Scrambler XP 1000 S service manual
      Download the 2020-2026 Polaris Scrambler XP 1000 S service manual PDF for complete factory repair, maintenance, troubleshooting, and diagnostic information. This comprehensive Polaris Scrambler XP 1000 S repair manual covers all major systems including engine service, EFI fuel injection, transmission and clutch repair, AWD drivetrain systems, suspension, steering, brakes, electrical troubleshooting, wiring diagrams, torque specifications, and factory maintenance schedules.
      Designed for high-performance ATV owners, mechanics, racers, and DIY enthusiasts, this factory-style service manual provides detailed step-by-step instructions and diagrams for servicing and rebuilding the Polaris Scrambler XP 1000 S sport ATV.
      Topics covered include:
      Polaris Scrambler XP 1000 S engine repair
      AWD and differential service
      Suspension and steering repair
      Brake system maintenance
      Oil change procedures and service intervals
      Popular related searches:
      2020 Polaris Scrambler XP 1000 S service manual PDF
      Scrambler 1000 S wiring diagram
      Polaris Scrambler torque specs
      Scrambler XP 1000 S maintenance schedule
      Polaris Scrambler troubleshooting guide
      This Polaris factory repair manual is ideal for riders looking to maintain, troubleshoot, repair, or upgrade their Scrambler XP 1000 S for trail riding, mud riding, racing, dunes, and extreme off-road performance.
