  • 2 years later...
    • By DaveswMN
      Thanks for any thoughts.
    • By Jaiidutch
      ok so ill try and make this as short as i can i really hope someone here can help me figure this out...
      bought a 2001 Mojave 250 from some one not running.. was running till ??somthing?? happend. was told before it stopped running it had a timing chain slap sound so the chain was replaced.
      got the quad home and did a compression test results were 0psi...lol decided to break the engine down n see whats going on. found a brand new timing chain installed and yet 2 valves pushed into the head..so i ordered a top end gasket set and all new valves and lapped them in. while the head was off i did a broke man leak down and filled the cylinder with thin oil and let it sit for a few days and none of it leaked so i assume the rings are good. reinstalled the head with new head gasket and valves. re did a compression test and I'm seeing 80psi(i don't really trust my cheap tester). I kick start the quad over and it will run for about 10 seconds and then die. I'm getting good blue spark. cleaned the carb and tried again... i can kick 10 times and it will only start for 10 seconds or so. swapped my carb, throttle cable & thumb throttle from my 87 Honda 250x to the Mojave and same result 10 seconds... had a friend bring over a known good working Mojave carb and you guessed it same results 10 seconds. even swapped to a back up stator that i have and same thing... what in the world is going on! i dont know what els to try
    • By Shannon
      Hey guys, just wanted to know if someone can help me figure out my year and model of my Arctic cat 450.
      ALL help is appreciated. 🤟
    • By Spartacus Stroppel
      So I have a 2001 Kawasaki prairie 300 I could not find tough country snow plow... it's a older plow too boot... so I made the plow mount and updated the plow with some skids.
      Mount plate is 1/4 steel plate and so are the pin points
      The skids are off a moose plow. I got some plumbing black pipe for holders to weld to the blade and braced it with pieces left over from the plow mount 1/4 steel...
      1/4 plate cost $45
      Skids cost $24
      U bolts and other hardware where $20
      I got the blade free
    • By Ryan Geiler
      New to the ATV world, picked up a solid used Kodiak 400.  It appears the former owner did some sort of modification for a saddle bag or something along those lines--and I'd like to match it up and replace it.  Not a big deal by any means but something I thought I would give a shot at finding.
      does anyone recognize what kind of luggage/bag/cargo would go where those white tabs are he drilled through that fuel fender?
      Thanks again
