Hi everyone, need some electrical wizardry, my 1998 LTF-4WDX has a ghost, it fires right up idles perfect but when throttling up starts dieseling , missing, real bad but when the ignition is turned to the lighting pos. everything is normal runs perfect, any help is most appreciated! I have checked: charging circuit / ok- changed ignition switch- no change, new coil. I'm scratchin my head so much it's starting to bleed! HELP!! Thanks for any thoughts.🤔🙄
  • Admin changed the title to 1998 Suzuki LTF-4WDX ignition/ electrical
Hi Mark, I had an extra ignition switch that I swapped out but same results, hadn't thought of the stop/run/off switch, guess I'll have to get into it and see what it's doing as far as continuity By the way is that your trike? Awesome!
    • By sandman001
    • By Rockbottom
      anybody have a electrical drawing
      cant figure out problem
      new starter relay, when i turn the key on all 3 leads to relay are hot red, blue, blue white. Is that correct. nothing happens ir clicks at the starter relay when i push the start button
      on the relay closest to the cdi and nearest the brake light the relay vibrates as if it is opening and closing rapidly
      the batter is new and good
      if i short the B and M lugs on the starter relay the engines turns over but does not start and there is no spark
      I ordered a new cdi but the one on the machine is only a few months old but a aftermarket
      anybody have a electrical drawing or advice ir know what that relay symptom is and what activates it
      thanks ahead
    • By BillR94
      Thank you for your time
      Bill
    • By HHurks
      Hi to all
      Newbie here. Not new to ATVs. Look forward to learning a few new things and hope to maybe help some too.
    • By jordan_ATV
