2021 Axis 500 Noise when coasting downhill
Similar Topics
By Fiend_138
Just picked up a 2014(?) Chinese quad for my kids to play around on. I can get the quad to start up, but then it dies out when we get ready to take off. Do I just keep playing with the carb, or is there something else I should be looking at?
Also, what kind of amps should I be looking for in a replacement battery?
By geezer99
Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago. This post will be about my impressions as I use, fix, and abuse the machine. I will add to the post as I gain experience with it.
Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections. Zirks were all freshly greased, fluids in engine, and gear boxes were up to level. One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
The rear gearbox does not have a differential in it. It is essentially a solid axle. Tight turns on lawn will leave tracks, and turns are not as tight on pavement. In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
To check engine oil you need to remove both front seats and a plastic cover. This according to the manual. I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
I am not used to a CVT transmission. I am used to a clutch and multiple gears. This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up. I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
The doors have bungie cords to act as springs to close them. I removed the driver door so I would not need to fight the constant pressure to close. Problem solved. I will leave the passenger door as is. Gotta keep the grandkids safe.
Here is some stuff I like:
I was concerned about there being enough torque to slowly climb a steep hill. There is. I will elaborate more on this when I've had it on my steeper trails.
The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff. This helps a beginner with feedback that an action taken was successful.
The sparsity of knobs on the tires dig in well on most surfaces. I bet they wear out fast on pavement.
The tilt bed has a tail gate that is easy to operate. Much like early Japan pickups.
Steering is responsive and little slack. Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
Seats are pretty nice. Will be interesting to see how long it will take me to poke a screw driver though them.
Seat belts are included to hold grand kids in. Won't go over 5 mph if both aren't buckled. Yeah, it works to buckle them empty. Doing this leaves the belt high on back, so you don't have to sit on it.
Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV. This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well. Creeping over the one well required climbing a 10 inch vertical well. The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well. The guys at Lowes were impressed. They won't touch any but an unobstructed flat trailer loading.
tom
By Machias_Mike
Hi there!
We just bought 4 acres and needed a work rig for moving stuff around and blazing trails. Been looking at buying a quad for a long time and finally got the opportunity. Found a very good condition 1994 Kawi Bayou 300 4x4. Runs great and seems to be in great operating condition with one little thing.
The unit seems to have an issue with reverse. Previous owner did tell me about it and its totally usable but the issue is annoying enough that I want to try and fix it. Im pretty mechanical oriented so don’t think this will (hopefully) be too much of an issue. I bought the kawasaki shop manual on ebay and should be here next Friday but wanted to get a head start on it.
The issue seems to be similar to this post but I think may be more mechanical than just the switch.
https://www.quadcrazy.com/atvforum/topic/14281-1994-bayou-220-neutral-safety-switch/
Here goes!
Neutral light is always on when key in on position I found that the green wire coming out of the block from neutral switch is grounded to chassis. When plugged in to switch light never turns on no matter what gear its in (and wont start). Machine can go from 1st directly into Reverse if you don’t feather it. This is the part that that makes me want to fix it. I feel like its dangerous and could possibly do some damage. It usually takes 3-4 tries to 'find' neutral. The reverse turn knob seems to be operable and cable is connected and operates the reverse 'selector' when turned. Springs back when released both at the switch and at the 'selector' inboard of the shifter. When in reverse the red reverse light does not illuminate Based on above and looking at the post above it seems that this would indicate that the reverse stopper is 'broken' and rotated in an 'in gear' position. I see a few posts on here where people have said it can crack. If I plug the green wire back in and turn machine to 'on' I can move the shifter through all gears and the neutral light and reverse light stay off. Again, to me it seems that the 'reverse stopper' is probably broken, stuck where the switch thinks its in a forward gear and the shaft is probably just spinning inside it.
Am I on the right track here?
I wanted to get a head start on this and looking at parts diagrams it looks like the part number for the 'reverse stopper' is 13091-1443, found one on ebay for $30 shipped. I hate buying parts before tearing it down but if this is the likely culprit I would take a $30 gamble to buy it so I can have it on hand when the manual arrives.
The other question I have which I hope is an easy answer is none of the parts diagrams I have found show the bevel gear gasket part number. Can anyone tell me what the part number is for this?
Many, many thanks for the info and I promise to post pics once I have it apart.
By Thegrizz
So, I just bought this quad off a acquaintance of mine… anyways, it’s missing the airbox which I’m trying to purchase if I could only figure out the year and what model of lt230 it is due to having only 9 visible digits for a vin…guy said he had the title at one point and lost it when he moved houses after the flood of 08 in Iowa….I just desperately need to know what model this thing is so I can start getting to work on it….it does run after a good carb cleaning….I’m having trouble getting it to idle though due to essentially just having a rigged up air filter with no airbox on the bike…I’ve sanded down the plastics and it looks like the original color was orange and the seat I believe is either from a different Suzuki or it’s been painted gold and black? The plastic nose part is originally black…it has the lever for reverse by the sprocket it has a pull string to start and I think originally it has electric start as well….idk I’ve had to bypass and use a screwdriver on the starter Solenoid to get it to start …someone has definitely done some rigging with the wiring as well.but if anyone has any clue what I need to look for to identify the year and actual model so I can get the right stuff. I’d appreciate it.
By kodiakbigbear4004x4
BEEN LOOKING AT LOWES AT THE NEW HISUN AXIS RHINO CLONES ANY ONE EXPEINCE THEM ARE THEY ANY GOOD OR IS THE MASSIMO BETTER LOOKIGN FOR AFFORDABLE UTV
Gallery Images
5
0By George Henry,
4
1
0By dirtmerchant42,
1
7By nyatvrida91,
3By blahhhh,
4By mannyortiz7,
0
3By mannyortiz7,
2By CK1999_400ex,
0
0By SeanKing,
2
0
4
4
5By mannyortiz7,
4
