Advertising
It's strange but I don't get much advertising. I'm a paid up member, but even before I was I never got much, nothing that I couldn't dismiss from the bottom of the page with a click of the mouse. If I sign out and come back as a guest I still don't get advertising, but, then, I'm using linux, so perhaps that explains it..  except.. I boot into windows ten, and I still don't see any advertising, no matter whether I'm signed in or a guest..
Perhaps there is some security setting or spam setting I've got right, or perhaps it's when people look in from their phone, which I haven't tried..  but for some reason, some of you sound like you get a lot more advertising that I do.
I reckon there will be a reason though..  Settings I suspect.
  • Similar Topics
    • By trx125flip
      yay forum stuff again... really needing a 87 trx125 service manual.. if anyone has one without a dead link that would be super!
    • By Mikey124
      I have a 89 Big Boss 250 I can get it to idle very slowly with no throttle response.  I did get it to run normally a couple times only after working the throttle every so slowly to get the RPM's up enough so that it would move.  Even when i did get it to run normally it bogged back down for a brief moment then came to normal.  Not sure if it's a fuel problem or if I should be looking into the ignition system for possible low voltage issue.
    • By Brantley11
      Hey everybody,
      My proficiency is with Hondas and Yamahas make me see RED!
      This bike is my brother in law's, it has 1199 miles on it and went from running great to dead with no start. Every once and a while it will start and sputter for 2 seconds. It is extremely sporadic when it fires but never runs for longer than 3 seconds.
      Here is where we sit:
      Brand New Fully Charged battery
      Carb was cleaned with air hose and carb cleaner then into the ultrasonic cleaner with Aircraft aluminum cleaner
      New Shindy Carb kit (made in Japan version)
      Cleaned out petcock and gas tank
      New 93 Non Ethanol Gas
      New Spark Plug
      It gets a spark through the spark test light every time
      Bluish white spark
      When holding the spark plug 1/4" - 3/8" away from head it will jump and spark to the head
      Good Compression
      Here are the readings:
      Pickup Coil 519 Ohms (range 459-561)
      Charging Coil 266 Ohms (range 270-330)
      Lighting Coil 0.700 (range 0.702-0.858)
      Spark plug Cap 10.58 Ohms (10kohms
      Ignition Coil Primary Coil 0.5 ohms (range 0.18-0.28 ohms)
      Ignition Coil Secondary Coil 8.20 kOhms (range 6.32-9.48 kOhms)
      Would y'all think stator and pick up coil, rectifier or CDI are the culprit?
    • By Kawinoob
      So title tells all. achine was sitting for two years untouched.
      I will post a picture with diagnostic path so far.
      Replaced defective start solenoid, starter grinding but engaging.
      Replaced all wiring in #1 splice with dark green, brown and red/white wires. Checked all other junctions.
      Pull start works phenomenally and starts instantly.
      Kill switch does absolutely nothing, but the key will stop the bike and allows it to start. Replaced key switch and pigtail at key switch. As of now all lighting is functional (was not before fixing it)
      The Good:
      -has new spark plug
      -valves were adjusted
      -key switch
      -wiring appears in order after repair
      -display functioning
      -new battery
      -always starts easily on pull rope
      -etc switch
      -pulsar coil
      - ignition coil
      I am replacing the bendix due to intermittent failure and gapping the pulsar tonight. Also, replacing battery cables and unplugging kill wire from cdi to isolate. Replacing battery wires to starter and ground cable.
    • DIY like a pro! Shop from over 1,000,000 Repair Manuals at eManualOnline.com! As low as $14.99 per manual. Shop now.
    • By Stephanie Webb
      I have a 2000 500 quadmaster lta an just rebuild the gear box an my high gear is like nuetral will not move but all other gears move nothing looks broke just need some help cant figure out what gear that would be or if it could be the shifter fork
  • Gallery Images
