It's strange but I don't get much advertising. I'm a paid up member, but even before I was I never got much, nothing that I couldn't dismiss from the bottom of the page with a click of the mouse. If I sign out and come back as a guest I still don't get advertising, but, then, I'm using linux, so perhaps that explains it..  except.. I boot into windows ten, and I still don't see any advertising, no matter whether I'm signed in or a guest..
Perhaps there is some security setting or spam setting I've got right, or perhaps it's when people look in from their phone, which I haven't tried..  but for some reason, some of you sound like you get a lot more advertising that I do.
I reckon there will be a reason though..  Settings I suspect.
Yeah but if I log in as a guest I don't get advertising..  I use mozilla firefox.. for linux, or Win ten with er..  some gimmicky thing..  Edge I think it's called. As a casual visitor I don't get much advertising..
I have all my security settings set to not interact with the world automatically as much as possible. I'm an internet hermit..
When I first signed up I got a few ads, just one click and they go away and after being on for about 3 months started getting more, I was so used to just clicking them off I didn't notice. About a month ago I started getting this square appearing in the middle of my screen and totally locked it until you watched an add, rather annoying. I am using Mac with Safari nothing special. I then decided to join, I had been meaning to anyway, this is the best site iv been on with a lot of activity and helpful people and I wanted to support it and the efforts of the Administrators.
    • By BillR94
      Thank you for your time
      Bill
    • By 97kingquad
    • By manning_cc
      Hello everyone! I have several ATVs for on farm use. 5 are Polaris : a Magnum 330, two sportsman 500 models, and two Sportsman 700 models.
      I also have a Yamaha and a Suzuki.
      All are older models and constantly needing repairs. So looking forward to wealth of knowledge on here 🙂
    • By TimothyLindblom
      Hi everyone, I’m new here and new to 4 wheelers. Just got a Yamaha bear tracker 250 and joined here to see if I could get some help.
      The motor runs and it drives if it up on jackstands but if you get on and try to ride it, it starts to drive but then quits after a foot or two and dies out and won’t drive. The guy I got it from said he was running and using it shifting through all the gears great and he started it up the next day and it started this.
      He told me he thought it was the U joint on the driveshaft. He said it was probably worn and needed to be replaced.
      I just finished pulling the swing arm and rear end assembly to check out the U joint and there’s no play in it. It’s tight and not nearly enough play to be loose enough to not catch and go.
      Any ideas on what it could actually be?
      Timothy
    • By heath
      i just bought a yamaha moto 4, i have sprayed 'start ya barstard' into the carb and on the spark plug and it doesnt even fire! although when i have the spark plug on the outside of the motor it shows spark, the engine also leaks oil from the starter,
